NI TestStand
Determine TestStand array maximum minimum
Is there a function to return a maximum and minimum array value for a TestStand array?
I could create a LV code module and pass the array in, evaluate using a LV function and return the results, but I'm looking for a TestStand native or possibly an ActiveX function...
(8,582 Views)
Hi Phillip,
In my opinion there no build in function providing this.
But you can do this by using two build in steps.
Iterate through the Array with the ForEach Step Type and then determine in a simple Statment step the MIN and MAX Value of your array
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(8,563 Views)
Accepted by topic author PhillipBrooks
Hi Phillip,
Try this example
Juergen
--Signature--
(8,558 Views)
This works fine. I didn't mention in my original post that I was looking to do this in TestStand 3.0.
I've just started looking at all the new features in 4.1 as part of the upgrade that I am responsible for. I might even try to create a template for this so that it can be easily dropped where need.
Thanks for the help!
(8,547 Views)
You can also use an expression-step with following content:
Sort(Locals.MyArray,True),
Locals.MyMin=Locals.MyArray[0],
Locals.MyMax=Locals.MyArray[GetNumElements(Locals.MyArray)-1]
Please be aware, that the second parameter in Sort-function reorders the origin array. If you don't want this behaviour, you will need a temporary array like this:
Locals.MyArrayTemp=Sort(Locals.MyArray,True),
Locals.MyMin=Locals.MyArrayTemp[0],
Locals.MyMax=Locals.MyArrayTemp[GetNumElements(Locals.MyArrayTemp)-1]
(4,574 Views)
