NI TestStand
Custom test report to include an additional column
Is it possible to add additional columns other than the default(step, Status, Measurement, Units, Limits) in the test report generated by Test Stand? I want to include additional data in other columns, example(Reference value, Time Stamp, Sequence number, etc) but so far I have not figured out how to do that, is there any way to do this?, Thanks.
Best Regards
Eder,
(1,224 Views)
Of course, you can customize, but to what extent with what level of effort?
This is an excellent article to start with - https://www.ni.com/en-us/support/documentation/supplemental/08/teststand-report-generation-and-custo...
Santhosh
Soliton Technologies
(1,211 Views)
Hi Santo_13,
OK, I just one to add for example, one single extra column which contains a global variable(reference value) in a ATML standard test report, I have already read the article but it include only the possibility to add a column with the stepID information, I want to have the possibility to add whatever I want in that extra column, is that possible?
(1,183 Views)
