NI TestStand
Deployment Utility and Labview Modules
I am fairly new to TestStand. I have created a TestStand Sequence that calls a number of Labivew modules. Everything works fine on my development machine.
I am trying to deploy this to another machine running a base development license. I ran the development utility and created a setup.exe which I have just installed on the 2nd machine.
When I go to run my test sequence on the 2nd machine it cannot locate the labview modules called in the test sequence.
So my questions are:
  1. Can TestStand deploy these files for me, or should I do it manually?
  2. If it can, is there a specific folder I should store all labview moduels on my development machine so the deployment utility picks them up?
  3. Is there any option in the Deployment Utility that I need to set for TestSTand to pick up these modules?
  4. Is there any special option I should set in the sequence file? Search area???
Thanks & Regards,
Don1.
(3,252 Views)
Accepted by topic author ShaneDonn
You should be able to see the LabVIEW VI's in your deployment tool. If you can't then that is why you can't see them on the target system.
Are you using a TestStand WorkSpace/Project files?
Deployment - Destination files
Ray Farmer
Message Edited by Ray Farmer on 02-11-2009 06:30 AM
Ray Farmer
(3,233 Views)
