Deploying TestStand2014
I have a problem with deploying TestStand 2014 runtime engine to run sequences on a test machine.
I have installed LabVIEW and TestStand from “NI Developer Suite 2015” on my development PC.
But when I am going to  "TestStand Deployment Utility” and tick checkbox to add NI TestStand Runtime 2014 SP1 to the installer it points "NI Developer Suite 2016" as a distribution title since I have only “NI Developer Suite 2015”:
When I ignore that and continue I am getting window:
When I use “NI Developer Suite 2015” popup appears:
I don't have active SSP program and don't won't to activate it only to download RunTime.
Is it possible to force installer to use “NI Developer Suite 2015” as a TestStand runtime source? Or maybe there is other way to install TestStand Runtime 2014 on test machine?
(1,186 Views)
Have You tried to check on NI Package Manager, maybe it downloaded automatically with the 15th?
regards.
(1,129 Views)
