 patrick1988
			patrick1988
			07-24-2008 01:54 AM
 RayFarmer
			RayFarmer
			07-24-2008 02:17 AM
The module time you can switch off by changing the Report Options in the Configure Reports..
The Comparsion Type and the IF statement, you will need to change the actual report generation sequence file.
The Sequence you need to change is the one to put a single result in report in reportgen_html.seq.
Remember not to modify the NI folder but copy the file to the User\.... folder and modify the file in the User folder then restart TestStand.
Ray Farmer
07-24-2008 03:57 AM - edited 07-24-2008 04:04 AM
 RayFarmer
			RayFarmer
			07-24-2008 05:27 AM
07-24-2008 05:46 AM
 RayFarmer
			RayFarmer
			07-24-2008 02:46 PM - edited 07-24-2008 02:47 PM
