06-22-2021 01:15 AM
I wish to delete a FileGlobal variable through TestStand from all the sequences which are opened or from all the sequence files which are present under project or workspace. I don't want to open each file and then delete that variable from there. Do we have anyway of deleting that FileGlobal variable from all sequence files on few clicks.
06-23-2021 04:03 AM
Hi rtingase,
If you mean from the Variables window (FileGlobals), so you can choose the first variable and pressing the Shift button to choose the last one, then press/choose to delete. With this action, the whole Global variables will be deleted from all sequences.
Best Regards,
Edgar Umrikyan.
06-24-2021 01:38 AM
I don't want to delete all the FileGlobal variables.
I want to delete single FileGlobal variable (eg- FileGlobals.EngineHours) from multiple sequences which are opened in TestStand.
07-08-2021 02:45 AM
You need to perform it manually for every sequence.
07-22-2021 03:40 PM
Here is a sequence file that shows how to create a fileglobal on the fly (in this case a boolean), as well as delete it.
create "test" fileglobal:
Locals.TemporaryObjectReference = RunState.Engine.NewPropertyObject(PropValType_Boolean,False,"",0), //Create new property Object
Locals.TemporaryObjectReference.AsPropertyObject.Name = "test",
FileGlobals.InsertSubProperty("",0,0,Locals.TemporaryObjectReference) // Insert property into station globals
delete "test" fileglobal
FileGlobals.DeleteSubProperty("test",PropOption_DeleteIfExists)
Hope this helps...
07-22-2021 10:13 PM
If I use this way, then I need to go in each sequence file and run these steps to delete variable. If I have 100 files with variable, then repetition of these steps will be time consuming.
Anyways, Thanks for your reply!
07-29-2021 01:52 PM
Use this VI over each SequenceFile with appropriate FileGlobal value (without the FileGlobals. prefix)
07-29-2021 10:05 PM
I could not open this VI because I am using LabVIEW 2017.
I think this VI is made in newer version.
10-12-2021 01:28 AM
Hey rtingase,
Please find the VI in attachment, I saved it based for LabView 2017.
