02-27-2008 08:51 AM
02-27-2008 01:53 PM
02-27-2008 02:21 PM
02-27-2008 02:27 PM
03-03-2008 02:23 AM
03-17-2008 09:02 AM
03-17-2008 10:45 AM
There are defined in an ini file in the \componenets\NI\language folder. I cannot remember the actual name of the file but you will see the obvious one when you look that folder.
You dont modify this file but put the Section key and the key with its new values in the CustomStrings.ini file in the User\language folder.
You dont need to add everything thats in the default file only the items that you want to change.
When TestStand launches it will use the values in the CustomStrings.ini instead of the default ini file.
Ray Farmer
03-18-2008 09:48 AM
04-15-2008 12:06 PM
