06-05-2020 04:25 PM
In the example below, you can insert VIs into an interface's subpanel if it's an absolute path or if it's in a project. Does anyone have an example where a VI is in a packed project library and then the VI is inserted into a subpanel?
So in TestStand, the VI path might be c:\ppl.lvlibp\test.vi
How do I get test.vi into my subpanel using similar code to the example?
06-08-2020 01:09 PM - edited 06-08-2020 01:11 PM
