10-31-2011 04:45 AM
Hi All,
I am trying to create a Custom step from Multiple Numeric Limit Test. The custom step by itself poplulates the Limits value from the measurement. So I am planning on hiding the Limits Tab in the step settings. Can someone guide me on how to do this ?
Prasaanthan
Solved! Go to Solution.
10-31-2011 05:00 AM
Prasaanthan,
if you do not need the Edit Substep at all, you can delete it from the substep list.
Keep in mind that TS gains a lot by using very focused modules. So including a module which does two things (taking measurements, populating limits) might beckfire one day result in "difficult to manage" applications.
hope this helps,
Norbert
10-31-2011 05:18 AM
Norbert,
Will removing the edit substep hide the Limits Tab in step Settings ??
Prasaanthan
10-31-2011 08:45 AM
To hide the Limits and/or Data Source tabs for your step type, edit the NI_Data.EditPanels array on your step type. Remove the elements that correspond to the tabs you want to hide.
10-31-2011 10:18 AM
Make sure that you have checked the "Show hidden properties" checkbox in the StationOptions >> Preferences. Otherwise, you will never find the array Erik refers to.
Norbert
11-01-2011 11:11 PM
Thanks Erik and Norbert.
I was able to succesfully hide the limits Tab. As Norbert mentioned we need to check the "Show hidden properties" for NI_Data.EditPanels to be listed. Once we remove the entry correspondig to the limits Tab, we need to restart Test stand for the changes to happen in the custom step.
Prasaanthan
