Custom Pass/ fail test step with Numeric entry in Measurement column
Hi All,Smiley Happy
I am developing a test sequence for testing a product ( consists of Pass/Fail and Numeric tests).
In test report (XML) against one of the pass/fail test, under Measurement column, I need to add a voltage value. I do not want to include it as report text, as it will add one more row to the test report table.
Is it possible in Test Stand 3.5? Please suggest how to implement.
SajK
(3,036 Views)
Hi SajK,
If you want to add an additional value to the report for a single step, add the data to the result list manually. If you want the same data on the report for each step of a certain type, you should modify the step type definition (create a custom step type as a copy of the given built in step type). In either case, these options are discussed in detail here:
How Do I Modify A Step Type To Log Data Into A Report?
For general information about TestStand report generation, please refer to this DevZone article:
Report Generation Explained
(3,010 Views)
