NI TestStand
Custom Install with modified DialogOptions.ini
I am attempting a custom non-interactive install of TestStand 2.0.1f by executing tssetup.exe followed by the -O option. The filename argument is my custom DialogOptions.ini file.
The tssetup.exe seems to ignore the -O option so I have to run tssetup\setup.exe with the -O instead.
Is this the correct behaviour? The install seemed to work but I wasn't sure what I was missing by not running the tssetup.exe in the root directory.
Thanks.
-Steve
(3,046 Views)
Hi Steve,
It appears that the command line options are not being passed correctly from the TSSetup.exe to the TSSetup\setup.exe file. You are doing nothing incorrectly. Using the TSSetup\setup.exe with the custom dialog options file will work. Hopefully there are not too many complications doing it this way. Sorry for any inconvenience this may have caused. Please let me know if you have any comments. Thanks!
(3,046 Views)
