04-17-2009 07:11 AM
THis was a slightly confusing thread...
Do Cet & Akie work together on this? 😉
04-19-2009 07:46 PM
04-23-2009 09:54 AM
04-23-2009 07:46 PM
04-24-2009 02:49 AM
04-24-2009 03:01 AM
Well...They have already finished thier intern last year when I started to take over the proj.My mentor said they did not know anything about Labview at that time,so they sent their VI to somewhere and got a lot of help...I am not very sure whether they have NI accounts,but I believe they don't.
Anyway,an intern is just a way to gain AUs for them.Maybe they are not major in such things, and we cannot expect too much,as long as their VI can run,it is considered as no problem...![]()
04-24-2009 03:21 AM
...they sent their VI to somewhere and got a lot of help...
This was created with help !? ![]()
With vi's written in this way, there is far too much room for human error to creep in - if just one of those many repetitive process blocks hasn't been wired up correctly then one of your outputs will be erroneous, but you may never 'see' it. Personally, for my own peace of mind, I'd be wanting to re-write most of that just to be throughly sure that it does work as expected.
Good luck with it!
04-24-2009 03:56 AM
04-27-2009 11:28 AM
Akie wrote:as long as their VI can run,it is considered as no problem
An important lesson in any programming language..
Being able to build & execute a software (making it run), is not an indication that it is doing what is supposed to do. Writing a software that simply does what it is supposed to do may not handle exceptions that will be encountered (errors, out of bound values, you-name-it, etc...)
Therefore, a software that runs is far from being without problems.. 😉
