From Friday, Oct 18th 11:00 PM CDT (Saturday, Oct 19th 4:00 AM UTC) through Saturday, Oct 19th 4:30 PM CDT (Saturday, Oct 19th 9:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
NI TestStand
Code modules bust be loadable
i get an error by starting my secquence the first time.
The error Name: Code modules must be able to load.
I can eliminate the error when I unlock the button "log" for the Report.
After the unlocking i haven´t any Errors.
Now I lock the "log for Report" button again and try the sequence again. And now i haven´t any Errors, too.
I attached a file of an example subsequence where I have the error.
Can somebody help me why I get the error, and why I get the error just one time?
Kind Regards
(2,978 Views)
Hi Andreas,
can you please try to open one of the TestStand Examples and observe if the error is happening there, too. You can find the examples under <TestStand Public>\Examples.
If the example program works, please upload the sequence file and a screenshot of the option you mentioned.
Best,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(2,938 Views)
thanks for your Reply.
The Examples are working.
I attached a screenshot of the error.
It doesn´t pay when you get the sequence because you havent the Hardware isn´t it?
Can you help me with this screenshot? Can you recognize the mistake?
Best
(2,935 Views)
Best
(2,934 Views)
Hi Andreas,
thank you for your reply.
Yes, I can not run the sequence, but I can take a look into the step configuration and the code module so I can get an idea of what is going wrong there. Can you please attach the sequence file and at lease one code module?
Best,
Melanie
Melanie Eisfeld
(2,932 Views)
thanks for your Support.
I have solved the Problem.
It was a LabVIEW Problem.
Kind Regards
(2,918 Views)
