Change the Open Sequence File initial path of the TestStand Simple Operator Interface with LabVIEW
I'm using a TestStand Operator Interface made with LabVIEW similar to the TS Simple OI example.
But I want to change the path when clicking the Open Sequence File button, I want a specific path.
All help is apreciated.
Daniel Coelho
Daniel Coelho
VISToolkit - http://www.vistoolkit.com - Your Real Virtual Instrument Solution
Controlar - Electronica Industrial e Sistemas, Lda
(4,254 Views)
Just need some help on how to specify the folder that TestStand opens when I click Open Sequence File.
Is there a way to do it on LabVIEW or on the TestStand configuration menus?
Daniel Coelho
(4,230 Views)
Accepted by Daniel Coelho
Daniel, you might be interested in this Knowledge Base:
How Do I Change the Default Directory for the Open File Dialog in TestStand?
I searched ni.com for open file dialog teststand and this was the fifth or so link.
Josh W.
Certified TestStand Architect
Formerly blue
(4,215 Views)
Thank you for your time.
You're right, I searched ni.com and I found the same link. I promise to search more carefully next time.
Although I wanted to do it programatically, this way works as well.
Thank you for your help one more time.
Regards.
Daniel Coelho
(4,199 Views)
Daniel,
          From a LabVIEW VI, you can make a similar call to "SetCurrentDirectory" in kernel32.dll using Call Library Function node.
Regards
Anand Jain
(4,195 Views)
Thank you for your reply.
I already tried to do it and it didn't work.
I called kernel32.dll and created a string argument with "C:\\EXISTING_PATH" but TestStand wasnt opening my selected folder.
Daniel Coelho
(4,193 Views)
