NI TestStand
Change module path programatically
I need to create a VI in LabVIEW to replace all code modules in a TestStand sequence. I tried doing so by getting all steps in the sequence through TestStand API, but I cannot find and property/method for step or module, that would allow me to get current path of the module and then replace that path with another one. Any ideas how to achieve this?
(3,219 Views)
In this example, step 4 covers creating a LabVIEW step and populating parameters.
https://forums.ni.com/t5/Example-Code/Creating-a-Sequence-File-with-a-LabVIEW-Module-Step-Using-the/...
(3,165 Views)
