NI TestStand
Cannot invoke API member LastStepResult on NULL object reference Step
hi guys,
I am using the Step list configurations  as "Execution Times"
& the Seq  during execution does not show execution time.
the  "Execution Times"  uses following code for modul time
(Step.LastStepResult != Nothing && Step.LastStepResult.Exists("TS.ModuleTime", 0)) ? Str(Step.LastStepResult.TS.ModuleTime) : ""
Step.LastStepResult  evaluates to  "Cannot invoke API member LastStepResult...."
it used   to function some time back......
(5,337 Views)
When does this error occur? While tracing? At a breakpoint? Always? only sometimes? Do you have an example which reproduces this problem? Also what version of TestStand are you using?
-Doug
(5,329 Views)
error occurs always
teststand 2012 sp1
i can send my step config file
i think it   depends on this file  as  the  module time cal is a  code in the  config.
i caqn send my file
(5,298 Views)
I'm having trouble reproducing the problem. Even in TestStand 2012 sp1, it seems to be working fine for me:
I copied and pasted the expression from your forum post, so I'm not sure what's different. Here's a copy and paste of the expression I'm using:
Perhaps you have another expression somewhere for a similar column that is leading to the error?
Hope this helps,
-Doug
(5,286 Views)
