Can you Resize the Message Popup?
Hi everyone,
Is there a way to resize the Message Popup box (found in the Insertion Palette)?
Thanks so much!
(4,845 Views)
The dialog box resizes automatically depending on the content.
You can also enable the user to resize the dialog to his own needs in the Layout tab.
Norbert
Norbert
Expert: Geometry
(4,820 Views)
Thanks Norbert.  One more question I have for you:
What if the Message Popup box is too small and you want it to be bigger for operator's to see it better?  Is there a way to do this so that the user does not have to change the size all the time?
Thanks so much!
(4,807 Views)
Hm, you could enter "empty" text or insert an image of the desired size.
The last option would be to create a custom popup dialog yourself (e.g. by using C# or LabVIEW) and use that instead of Message Popup.
Norbert
Norbert
Expert: Geometry
(4,803 Views)
