NI TestStand
Callback PostResultListEntry from Mainsequence in Plugin
Dear all,
I am creating a customer-specific report and would like to collect various data for each ResultListEntry of the test sequence. Is there a way that I do not use the SequencePostResultListEntryCallback within my test sequence, but that I use a callback within my created plugin that is executed after every entry in the result list?
Thanks a lot....
(2,196 Views)
Accepted by T.
Do you have OnTheFly turned on? If that's the case just configure it so OnTheFly gets called every time a result list entry is added. Then in your plugin you can just use Model Plugin - OnTheFly Step Results callback.
(2,176 Views)
Thanks for your suggestion. I will try it....
(2,145 Views)
yes it works that way, but unfortunately it is not yet clear to me how to interpret the data in the Results container. But I think I'm going to find out.
Thanks to everyone ...
(2,111 Views)
