in data 04-14-2015 01:06 PM
How to call teststand using LabVIEW and update LabVIEW indicator?
both should run parallely and for this VI i only pass a file path of sequence.( except UI example suggest me some other example)
best regards
Risolto Andare alla soluzione.
in data
04-14-2015
01:13 PM
- data ultima modifica
10-17-2025
11:50 AM
autore
Content Cleaner
Usually you would have a User Interface call TestStand. The UI can be built in LabVIEW. Here is document on UI development:
Then you use UI Messages to communicate back and forth between the UI and your sequence file.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3tWCAQ&l=en-US
Hope this helps,
in data 04-14-2015 01:33 PM
Thanks a lot
in data 04-14-2015 01:35 PM
Feel free to post any questions about it here. It can get a little tricky sometimes.
in data 04-15-2015 12:58 AM
I am using the VI ( C:\Program Files (x86)\National Instruments\TestStand 2014\UserInterfaces\Simple\LabVIEW\Source Code) which gives an example for simple UI and i am loading simple Teststand seq which has only message pop step and for loop with i and N intialisation .
Now i need to see the i and N values in my LabVIEW indicator I know how to read but in this Example i am not getting where to add my code?
in data 04-15-2015 09:48 AM
Where are you getting the sequence context from? Did you read the article on UI Messages? I'm not sure you are doing it correctly.
in data 04-16-2015 06:39 AM
Hi
I didnot read UI article before, Now I read its a great article .
Thanks a lot
Best Regards
Manasa
in data 04-19-2015 11:56 PM
Hi
I have created User message callback in reg event call back in simple UI example. after that created subVI call back and writen this code stilli am not able to update teststand variables values in labview please suggest me if anything wrong
regards
MGL
in data 04-20-2015 12:27 PM
You need to pass a reference to your front panel control and then use a property node to set the value. You cannot pass the value like that.
Hope this helps,
in data 04-20-2015 12:28 PM
You are on the right track though.
