NI TestStand
CTD Exam Material Question
I am trying to teach myself how to use TestStand and downloaded the CTD exam prep material.  I tried to open up the example exam solution but it is missing all the associated files.  I thought what I needed to do was install the NI Package files and then all the files that I would need would be installed but that didn't work? See below.  Can someone please walk me through how to get the sample exam program (sequence file) running?  Thank you
(2,202 Views)
Accepted by topic author CollinsAero
The exam contents get installed here: C:\Users\Public\Documents\CTD_Test
If you add that to your search directories you should be good.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,168 Views)
It looks like you will need to check the search subdirectories box as well.
jigg
CTA, CLA
testeract.com
(2,166 Views)
