06-29-2020 10:08 PM - edited 06-29-2020 10:10 PM
I am trying to teach myself how to use TestStand and downloaded the CTD exam prep material. I tried to open up the example exam solution but it is missing all the associated files. I thought what I needed to do was install the NI Package files and then all the files that I would need would be installed but that didn't work? See below. Can someone please walk me through how to get the sample exam program (sequence file) running? Thank you
06-30-2020 09:13 AM
The exam contents get installed here: C:\Users\Public\Documents\CTD_Test
If you add that to your search directories you should be good.
06-30-2020 09:22 AM
It looks like you will need to check the search subdirectories box as well.
