NI TestStand
Build a test sequence from a script
Hello all,
I want TestStand to build a sequence based on a pseudo code script. For example, the script would look like:
Power on
Voltage1 12
Voltage2 24
Circuit1 Short2Batt
Circuit1 Open
Circuit1 Normal
Power off
I want TestStand to build a sequence that would call some pre-build sub-sequences based on the script.
I know this is possible, but I have no idea where to begin to look.
Chase
(4,559 Views)
The <TestStand Examples> folder has at least one example of how to generate sequences. SequenceBuilderTool jumps out at me but I think there's a couple others demonstrating various sequence file translators (text, CSV, and so on).
(4,549 Views)
Hi Bladhart,
I did a similar stuff http://ftp.ni.com/pub/branches/germany/vipdays_09_sessions/Automotive_5_Automatische_Dodek.pdf.
My script was done in XML. For creating the SequenceFile i have used the TS-API.
My Maybe this threads could be interresting for you. They will show how to use these API Calls in Teststand itself.
On this Thread there is an example with Labview Adpater
http://forums.ni.com/t5/NI-TestStand/Create-a-LabV​IEW-Step-dynamically/m-p/977348#M25792
On this here with SequenceCall Adapter
http://forums.ni.com/t5/NI-TestStand/Insert-SubSeq​uence-Call-Step-using-TS-API/m-p/628857#M17591
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,503 Views)
@j_dodek wrote:
Hi Bladhart,
Hope this helps
Juergen
Hi Juergen,
Is there an English version of this, it looked interesting
Regards
Ray Farmer
(4,501 Views)
Hi Ray,
I am sorry, this is only available in german.
Regards
Juergen
--Signature--
(4,498 Views)
