‎11-09-2010 12:13 PM
Hello all,
I want TestStand to build a sequence based on a pseudo code script. For example, the script would look like:
Power on
Voltage1 12
Voltage2 24
Circuit1 Short2Batt
Circuit1 Open
Circuit1 Normal
Power off
I want TestStand to build a sequence that would call some pre-build sub-sequences based on the script.
I know this is possible, but I have no idea where to begin to look.
Chase
‎11-09-2010 02:57 PM - edited ‎11-09-2010 03:04 PM
The <TestStand Examples> folder has at least one example of how to generate sequences. SequenceBuilderTool jumps out at me but I think there's a couple others demonstrating various sequence file translators (text, CSV, and so on).
‎11-11-2010 04:21 AM
Hi Bladhart,
I did a similar stuff http://ftp.ni.com/pub/branches/germany/vipdays_09_sessions/Automotive_5_Automatische_Dodek.pdf.
My script was done in XML. For creating the SequenceFile i have used the TS-API.
My Maybe this threads could be interresting for you. They will show how to use these API Calls in Teststand itself.
On this Thread there is an example with Labview Adpater
http://forums.ni.com/t5/NI-TestStand/Create-a-LabV​IEW-Step-dynamically/m-p/977348#M25792
On this here with SequenceCall Adapter
http://forums.ni.com/t5/NI-TestStand/Insert-SubSeq​uence-Call-Step-using-TS-API/m-p/628857#M17591
Hope this helps
Juergen
‎11-11-2010 04:39 AM
@j_dodek wrote:
Hi Bladhart,
Hope this helps
Juergen
Hi Juergen,
Is there an English version of this, it looked interesting
‎11-11-2010 05:38 AM
