Batch execution trace event
i know but i have no idea how to do it - e.exec is taken from the event content , how can i assign different socket's execution
as for now, you instructed me to duplicate seqmgr and execmgr
is this enough ? what about the appmgr?
my main issue is to assign(find) different socket's executions
Message 11 of 19
(1,840 Views)
The socket ID is part of the name of the execution.....
Hint: The execution name is used in Sequence Editor to name the socket execution sub-windows.
A simple if-clause is enough for assigning the sockets execution correctly.
Norbert
Expert: Geometry
Message 12 of 19
(1,839 Views)
I appreciate your responses but at this stages hints are not helpful
I need strict anwers please )
Message 13 of 19
(1,837 Views)
Norbert ?
Message 14 of 19
(1,827 Views)
if- or switch on e.exec.displayname
Norbert
Expert: Geometry
Message 15 of 19
(1,825 Views)
Thanks Norbert
the thing is I get trace events (exec events) only for a single socket
what i am missing is the ability to get exec events for all 4 sockets than I can fully control it
do you understand my issue ?
thanks,
Ori
Message 16 of 19
(1,804 Views)
Accepted by Oric
Message 17 of 19
(1,792 Views)
thanks, this was exactly the main key solving my issue
now to the next challenge : endexec event is not envoked for some reason when running the batch model
i do get ts pop up which summarizes 4 units results but i dont catch each socket's end exec event ( i want extra handling in my code)
Message 18 of 19
(1,787 Views)
Unless you run SinglePass, the executions for the sockets "end" only if you stop testing for the whole batch(es). Depending on the use-case, you could for instance use the DisplayReport event.
Norbert
Expert: Geometry
Message 19 of 19
(1,776 Views)
