NI TestStand
Background color of TestStand 2012 User Interface Reverts Back to Default After Changing
I changed the background color and other properties of the Execution and Sequence TestStand Controls in the TestStand 2012 User Interface example code. When I execute the Top Level.vi the TestStand User Controls revert back to their default colors/properties. I saw this problem in the list of TestStand 2010 known issues, is it also a known problem in 2012?
(3,659 Views)
Hey kelsayd,
I just tried changing the color of the user interface controls in my user interface (from TestStand 2012) and saw the same behavior. I believe this is because the controls are ActiveX controls and do not permit the same level of customization as LabVIEW controls. I did find this KnowledgeBase article, which mentions the issue and gives one possible solution to the issue: http://digital.ni.com/public.nsf/allkb/4E40FA5AEAF3937B86256E89007C74C4?OpenDocument
Hopefully that will help show how you can set this up, and let us know if you have any further questions about it!
(3,643 Views)
Another option might be to change the settings of the ActiveX button to "Style -> Toolbar" and work with "BackColor". The disadvantage of this approach is that indication of the state "idle" vs. "pressed" is not present anymor except the mouse hovers above the button (esp. important for toggle buttons).
Norbert
Norbert
Expert: Geometry
(3,638 Views)
