Access on step.result.string in post expression fails
I try to copy the content of Step.Result.String in the post expression of a string value test to a local variable. Data.Source of this step is not the default value. The first time the step is executed, the local stays empty. If the step runs a second time (Test UUTs or break & set next step), the post expression works.
The attached sequence demonstrates this bug. Watch as "StringValueTest2" fails the first time and passes after this. I'm using Teststand 2.0.1
(3,072 Views)
Step.Result.String is updated in the "status expression" :(Step.DataSource != "Step.Result.String" ? Step.Result.String = Evaluate(Step.DataSource) : False;), but you update the "Locals.dummy" in the post expression witch is executed just before the status expression.
Then try "Locals.dummy = RunState.PreviousStep.Result.String" in the pre-expression of the second test and it will work.
Slts
JMC
JMCe
(3,072 Views)
