NI TestStand
Access a Station variable using Local Variable value
I'm trying to access the value of an Station Global depending on the value from a Local variable that will populate at runtime.
Eg. Instead of pointing to my Station Global in the following way: StationGlobals.Instrument1.Test
I want to use the value from a Local variable (Locals.Instrument) that will populate with the values 'Instrument1', Instrument2' or 'Instrument3' depending on the test.
Something like this:
StationGlobals.'Locals.Instrument'.Test
Is that something possible?
I hope my explanation is clear.
Thank you.
(1,349 Views)
Accepted by CesM
You can do it in many ways. See attached example.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,314 Views)
I really appreciate your help!
(1,304 Views)
