Access System.IO.Ports with .NET Module
Using mscorlib Assembly in the module, I don't see the selection for System.IO.Ports.  Trying to use with a .NET SerialPort.  Has anyone had success in using within a sequence directly or do I need to create a wrapper DLL for this?
(2,501 Views)
Came across the need for this again.  Dropping in a reply to see if anyone had a solution to this issue.
(2,259 Views)
Accepted by testergi
It is possible as shown below,  you've been looking at the wrong dll, you need to select System.dll
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(2,249 Views)
Thanks @santo_13.  I actually found it soon after sending the last post.  Thanks for the response. 🙂
(2,242 Views)
