API to get File Globals Separate/Shared Setting
Hi all,
Does anyone know how to get the File Properties Sequence File Globals setting pragmatically? I can get most of the other settings from the Sequence File pragmatically, but this one is eluding me. I'm using TestStand v4.2.1
-Jack
(3,258 Views)
Hi Jack,
It seems there is no "real" API call for this available,
but you may access the Data Object...
just use this:
Statement:
RunState.SequenceFile.Data.SFGlobalsScope = 1
API:
SequenceFile.Data.AsPropertyObject().SetValNumber("SFGlobalsScope",1)
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,245 Views)
Accepted by topic author Captain_Jack
Thanks Juergen!
Your response got me pointed at what I needed, which was to get the value:
 int sfGlobalsScope = (int)args.SeqFile.AsPropertyObjectFile ().Data.GetValNumber ("SFGlobalsScope", 0);
Thanks again for your help!
-Jack
(3,197 Views)
