10-22-2025 06:01 AM - edited 10-22-2025 06:43 AM
Any idea how to fix this.
An error occurred while installing a package: ni-package-manager-upgrader (25.8.0.49292-0+f140)
Additional error information:
• The executable returned error '1' after running the custom execute command 'path='"\\?\C:\WINDOWS\system32\reg.exe"', options='add "HKEY_LOCAL_MACHINE\Software\National Instruments\NI Package Manager\CurrentVersion" /v UpgraderExecutableFullPath /t REG_SZ /d "%ni-paths-NIPMDIR64%Updater\Install.exe" /f''.
Solved! Go to Solution.
10-22-2025 06:42 AM
Additional information.
This is from a fresh install of package manager 2005 Q4, after uninstalling all NI software from my laptop.
I also saw a similar error, when trying to install LabVIEW with an Older version of Package Manager 2025 Q1, when it tried to upgrade to 2005 Q4
10-22-2025 07:00 AM
Can you check if the registry key already exists in your registry?
reg.exe micght throw an error here if the key is already existing....
10-22-2025 09:08 AM - edited 10-22-2025 09:09 AM
It seems the corporate IT policy has disabled registry write permissions.
Temporarily had permissions granted and is now installing correctly.
