NI Package Manager (NIPM)
NIPM - error 1708 when installing msi pacakge in docker
I am trying to isntall the follwoing package:
nipkg install --yes --accept-eulas ni-scope-23.0.0-dotnet-fx45-support
The following packages will be installed:
 ni-cabled-pcie, ni-controllerdriver, ni-mru, ni-mximanager, ni-mxs, ni-pcibrd,
 ni-pxiplatformframework, ni-pxiplatformservices-expert,
 ni-pxiplatformservices-runtime, ni-qpxi, ni-roco,
 ni-scope-23.0.0-dotnet-fx45-runtime, ni-scope-23.0.0-dotnet-fx45-support,
 ni-scope-runtime-core, ni-visa-headers, ni-visa-shared-components,
 ni-xerces-delay-load
Recommended packages not included (see --include-recommended option):
 ni-certificates
Installing 17 package(s); Upgrading 0 package(s); Removing 0 package(s); Downgrading 0 package(s)
Need to get 50.26 MB of archives.
After this operation, 0 bytes of additional disk space will be used.
Installing ni-controllerdriver: 50%
Error -125083: An error occurred while installing a package: ni-controllerdriver (23.0.0.49336-0+f184)
Additional error information:
Error -125530: An error occurred while installing the MSI at 'controllerDriver64.msi'.
When I dig deeper into msi logs it displays:
MSI (s) (00:8C) [13:40:37:782]: Note: 1: 1708
MSI (s) (00:8C) [13:40:37:782]: Product: NI Controller Driver 23.0 64-bit -- Installation failed.
Attached full log from instalation.
Is there a way to continiue instalation despite this error or fix it?
(2,430 Views)
Accepted by pawhan11
NI software that depends on NI drivers will fail to install under Docker because Docker does not support installing drivers.
Technically you could create and install a custom package that uses the Provides attribute that contains the list of packages that you want to prevent from being installed, so you could list the ni-controllerdriver package. How any software that requires those drivers be installed will vary and will minimally error and could crash the software.
Scott Richardson
https://testeract.com
(2,381 Views)
