NI Package Manager (NIPM)
Authentication/Proxy for NIPM (nipkg.exe)
I'm currently playing around with the --proxy and --proxy-user settings for nipkg.exe, in relation to questions like Oli's here: https://forums.ni.com/t5/NI-Package-Manager-NIPM/Feed-URL-gt-how-does-NIPM-handle-user-credentials/t...
(i.e. because you can't currently use authentication parameters anywhere else than for the proxy server).
I have a few questions (numbered in the hope of a reply with reference, rather than by order or importance):
  1. Why do both `feed-add` and `feed-update` have proxy parameters? (Are the values passed to feed-add stored for that feed? If I run nipkg.exe feed-update my_proxied_feed after using the params for feed-add --name "my_proxied_feed" --proxy="http://blah.com:<port>" --proxy-user="cbutcher:password" "http://mypackagehost.com/package-repo", should I expect the proxy values to be used?
  2. Are there other settings that control if/when the proxy values are used? (in particular, does NIPM confirm the 'remoteness' of a URL before attempting to use a proxy? Or attempt to hit it directly first, then fall back to the proxy?)
  3. Is there a timeline for adding auth options to the feeds without considering proxies?
  4. Will NIPM warn me if I pass values that don't match its expectations? (This seems to be not the case, but perhaps it allows a wide range of inputs). In particular, are things like `--proxy="http://hostname:port/some/trailing/path" (or http://hostname.com/path/to/route:port) allowed? (I recognise this is not a typical proxy argument, and further that the nipkg.exe help lists "[<protocol>://]proxyhost[:<port>]"
GCentral
(1,132 Views)
I am not all that familiar with NIPM proxy from my time at NI. If helpful, proxy settings can be specified for every command that could require them, or you can set user or system settings using nipkg.exe -config-set.
FWIW, some potentially related articles to be aware of:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGU5CAO&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGU9SAM&l=en-US
Scott Richardson
https://testeract.com
(1,062 Views)
