06-15-2021 03:27 AM
An error occurred while upgrading the package from'ni-ssp-notifier(19.0.0.49152-0+f0)' to'ni-ssp-notifier(20.6.0.49152-0+f0)'.
06-16-2021 10:04 AM
Channica, it would be helpful to those that follow this forum to know the following:
1) What version of NIPM is installed on the system?
2) What were you installing when the error occurred, and was it a small online installer, an full offline installer, or were you installing from a product from the Browse Products tab in NIPM?
3) Can you capture and share the logs for NIPM associated with the installation as outlined in the following KB? It would be helpful to enable MSI logs and capture those if you can still reproduce the issue.
06-20-2021 05:55 AM
This is an error that NI Package Manager returns when there was an issue installing or removing a package. To determine the underlying issue causing the error to occur, you can look at the NI Package Manager logs .
The troubleshooting steps you can try out:
Hope this will help you to find the solution.
06-20-2021 08:52 PM
thanks
07-01-2025 06:44 AM
Alternatively, you can restart the install, and uncheck any packages you don't need to have. Try the install again and see if it goes through. I would try this before doing a full uninstall - especially if you're like me and run several versions on the same machine.
