NI Linux Real-Time Discussions
error while loading shared libraries: libcrypto.so.1.0.0
I have application written in C and I have added some message digest functions using openssl and libcrypto. I have linked the library in the Eclipse project via "-lcrypto" and "#include <openssl/evp.h>" in the C file. The application builds fine. However when I deploy and start the application on the cRIO, I am getting the following error at launch:
"error while loading shared libraries: libcrypto.so.1.0.0: cannot open shared object file: No such file or directory"
I see that my cRIO has libcrypto.so.1.0.2 located in /usr/bin/
I assume I have some version issue. I would have thought 1.0.2 would be enough, does my application specifically call 1.0.0 without me explicitly calling it?
admin@NI-cRIO-9030-01C59BCD:/usr/lib/x86_64-linux-gnu/nisysapi# opkg info openssl
Package: openssl
Version: 1.0.2k-r0.40
Depends: libc6 (>= 2.24), libcrypto1.0.2 (>= 1.0.2k), libssl1.0.2 (>= 1.0.2k), openssl-conf
Status: install ok installed
Architecture: core2-64
Installed-Size: 567978
Installed-Time: 1537439537
Ok, so it looks like my includes in Eclipse points to C:\build\17.0\lib\, which has libcrypto.so.1.0.0.
My cRIO feed is from 18.5, libcrypto.so.1.0.0 is not in //lib. I did find it here /usr/lib/libcrypto.so.1.0.2 Is this a linking/path issue?
Edit:
I tried creating a symbolic link and now I get this...
admin@NI-cRIO-9030-01C59BCD:/usr/lib# ln -s /usr/lib/libcrypto.so.1.0.2 /lib/libcrypto.so.1.0.0
admin@NI-cRIO-9030-01C59BCD:/usr/lib# /usr/local/bin/app
/usr/local/bin/app: /lib/libcrypto.so.1.0.0: version `OPENSSL_1.0.0' not found (required by /usr/local/bin/app)
Which looks like I need to either install openssl1.0.0 on the cRIO or somehow load openssl1.0.2 on my PC and include in the project build?
Edit:
I downgraded to 2017 drivers and now I have this:
admin@NI-cRIO-9030-01C59BCD:/usr/lib# find / -name libcrypto.so*
/usr/lib/libcrypto.so.1.0.0
admin@NI-cRIO-9030-01C59BCD:/usr/lib# opkg info openssl
Package: openssl
Version: 1.0.2h-r0.121
Depends: libssl1.0.0 (>= 1.0.2h), libc6 (>= 2.23), libcrypto1.0.0 (>= 1.0.2h)
Section: libs/network
Maintainer: NI Linux Real-Time Maintainers <nilrt@ni.com>
MD5Sum: 2ad8c9cc88bee78ee182e1f89a0a5a02
Filename: openssl_1.0.2h-r0.121_core2-64.ipk
Source: http://www.openssl.org/source/openssl-1.0.2h.tar.gz file://find.pl;subdir=openssl-1.0.2h/util/ file://run-ptest file://configure-targets.patch file://shared-libs.patch file://oe-ldflags.patch file://engines-install-in-libdir-ssl.patch file://debian1.0.2/block_diginotar.patch file://debian1.0.2/block_digicert_malaysia.patch file://debian/ca.patch file://debian/c_rehash-compat.patch file://debian/debian-targets.patch file://debian/man-dir.patch file://debian/man-section.patch file://debian/no-rpath.patch file://debian/no-symbolic.patch file://debian1.0.2/version-script.patch file://openssl_fix_for_x32.patch file://fix-cipher-des-ede3-cfb1.patch file://openssl-avoid-NULL-pointer-dereference-in-EVP_DigestInit_ex.patch file://openssl-fix-des.pod-error.patch file://Makefiles-ptest.patch file://ptest-deps.patch file://openssl-1.0.2a-x32-asm.patch file://ptest_makefile_deps.patch file://configure-musl-target.patch file://parallel.patch file://CVE-2016-2178.patch file://CVE-2016-2179.patch file://CVE-2016-2180.patch file://CVE-2016-2181_p1.patch file://CVE-2016-2181_p2.patch file://CVE-2016-2181_p3.patch file://CVE-2016-2182.patch file://CVE-2016-6302.patch file://CVE-2016-6303.patch file://CVE-2016-6304.patch file://CVE-2016-6306.patch file://0001-crypto-rand-Fix-VxWorks-platform-detection-in-randfi.patch file://0002-crypto-ts-Implement-def_time_cb-on-VxWorks.patch file://0003-ssl-Implement-get_current_time-on-VxWorks.patch file://0004-crypto-bio-Implement-get_current_time-on-VxWorks.patch file://0005-crypto-Implement-OpenSSLDie-as-abort-on-Phar-Lap-ETS.patch file://0006-crypto-Remove-unsupported-headers-in-cryptlib.c-on-P.patch file://0007-crypto-rand-Disable-unsupported-readscreen-on-Phar-L.patch file://0008-crypto-rand-Don-t-include-unsupported-Windows-header.patch file://0009-rand_win.c-Stub-RAND_poll-on-Phar-Lap-ETS.patch file://0010-crypto-des-Disable-WIN_CONSOLE_BUG-hack-on-Phar-Lap-.patch file://0011-crypto-ui-Disable-WIN_CONSOLE_BUG-hack-on-Phar-Lap-E.patch file://0012-crypto-bio-Disable-xopenlog-xcloselog-on-Phar-Lap-ET.patch file://0013-crypto-Use-i686-instead-of-i486-in-MASM-script.patch file://0014-perlasm-x86masm.pl-make-it-work.patch
Description: Secure Socket Layer Secure Socket Layer (SSL) binary and related
cryptographic tools.
Installed-Size: 553336
Installed-Time: 1489192102
admin@NI-cRIO-9030-01C59BCD:/usr/lib# /usr/local/bin/eclipse_backend
/usr/local/bin/eclipse_backend: /usr/lib/libcrypto.so.1.0.0: version `OPENSSL_1.0.0' not found (required by /usr/local/bin/eclipse_backend)
Seems like I am closer with now having "libcrypto.so.1.0.0" but something still wants OpenSSL 1.0.0. Looks like I have some mismatch.
I am seeing that NI has moved and Linux RT developement from Eclipse (<2017) to Visual Studio. IF there is some package issue in NI's feeds for OpenSSL that is causing this issue, do I need to move to VS?
Doug Ferguson
Message 1 of 11
(20,430 Views)
Hey Doug,
Can you rule out any search path issues with ldd? You can install it with opkg (I think the package is literally just ldd) and try running it on your application with and without the -v flag. That should give you an idea of what's missing and where it is looking for linked dependencies.
Admittedly might just point at OpenSSL as you've already noted, but it's a good check to make.
Charlie J.
Message 2 of 11
(20,350 Views)
admin@NI-cRIO-9030-01C59BCD:/usr/local/bin# ldd -v /usr/local/bin/eclipse_backend
linux-vdso.so.1 (0x00007fffe47b5000)
libm.so.6 => /lib/libm.so.6 (0x00007fa5c5f77000)
libcrypto.so.1.0.0 => /usr/lib/libcrypto.so.1.0.0 (0x00007fa5c5b2e000)
librt.so.1 => /lib/librt.so.1 (0x00007fa5c5926000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00007fa5c5709000)
libc.so.6 => /lib/libc.so.6 (0x00007fa5c5369000)
/lib/ld-linux-x86-64.so.2 (0x00007fa5c627c000)
libdl.so.2 => /lib/libdl.so.2 (0x00007fa5c5165000)
Version information:
libcrypto.so.1.0.0 (OPENSSL_1.0.0) => not found
librt.so.1 (GLIBC_2.2.5) => /lib/librt.so.1
libpthread.so.0 (GLIBC_2.4) => /lib/libpthread.so.0
libpthread.so.0 (GLIBC_2.12) => /lib/libpthread.so.0
libpthread.so.0 (GLIBC_2.3.3) => /lib/libpthread.so.0
libpthread.so.0 (GLIBC_2.3.2) => /lib/libpthread.so.0
libpthread.so.0 (GLIBC_2.2.5) => /lib/libpthread.so.0
libm.so.6 (GLIBC_2.2.5) => /lib/libm.so.6
libc.so.6 (GLIBC_2.14) => /lib/libc.so.6
libc.so.6 (GLIBC_2.3) => /lib/libc.so.6
libc.so.6 (GLIBC_2.7) => /lib/libc.so.6
libc.so.6 (GLIBC_2.2.5) => /lib/libc.so.6
/lib/libm.so.6:
ld-linux-x86-64.so.2 (GLIBC_PRIVATE) => /lib/ld-linux-x86-64.so.2
libc.so.6 (GLIBC_PRIVATE) => /lib/libc.so.6
libdl.so.2 (GLIBC_2.2.5) => /lib/libdl.so.2
/lib/librt.so.1:
libpthread.so.0 (GLIBC_PRIVATE) => /lib/libpthread.so.0
libc.so.6 (GLIBC_2.3.2) => /lib/libc.so.6
/lib/libpthread.so.0:
ld-linux-x86-64.so.2 (GLIBC_2.2.5) => /lib/ld-linux-x86-64.so.2
/lib/libc.so.6:
ld-linux-x86-64.so.2 (GLIBC_2.3) => /lib/ld-linux-x86-64.so.2
/lib/libdl.so.2:
admin@NI-cRIO-9030-01C59BCD:/usr/local/bin# ldd /usr/local/bin/eclipse_backend
linux-vdso.so.1 (0x00007ffe5d84f000)
libm.so.6 => /lib/libm.so.6 (0x00007f7c1cdd8000)
libcrypto.so.1.0.0 => /usr/lib/libcrypto.so.1.0.0 (0x00007f7c1c98f000)
librt.so.1 => /lib/librt.so.1 (0x00007f7c1c787000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00007f7c1c56a000)
libc.so.6 => /lib/libc.so.6 (0x00007f7c1c1ca000)
/lib/ld-linux-x86-64.so.2 (0x00007f7c1d0dd000)
libdl.so.2 => /lib/libdl.so.2 (0x00007f7c1bfc6000)
Doug Ferguson
Message 3 of 11
(20,348 Views)
I wanted to try calling openssl directly form the command line:
admin@NI-cRIO-9030-01C59BCD:/usr/local/bin# openssl dgst -sha256 /etc/eclipse/eclipse_config
openssl: /usr/lib/libssl.so.1.0.0: version `OPENSSL_1.0.1' not found (required by openssl)
openssl: /usr/lib/libssl.so.1.0.0: version `OPENSSL_1.0.0' not found (required by openssl)
openssl: /usr/lib/libcrypto.so.1.0.0: version `OPENSSL_1.0.1' not found (required by openssl)
openssl: /usr/lib/libcrypto.so.1.0.0: version `OPENSSL_1.0.0' not found (required by openssl)
admin@NI-cRIO-9030-01C59BCD:/usr/local/bin# opkg install openssl-dev
Upgrading openssl from 1.0.1e-r15.0 to 1.0.2h on root
Installing openssl-dev (1.0.2h) on root
Configuring openssl.
Configuring openssl-dev.
SHA256(/etc/eclipse/eclipse_config)= 459ff1c513d34441590cf8c616cafb723840ffeeec0b76a3dc3d0396e962253e
 I was able to get the same type of error and resolved ir by installing 'openssl-dev'.
However I can't resolve the same error when called by my application...
Doug Ferguson
Message 4 of 11
(20,344 Views)
More information....
admin@NI-cRIO-9030-01C59BCD:/usr/lib# strings /usr/lib/libcrypto.so.1.0.0 | grep "1\.0"
libcrypto.so.1.0.0
OPENSSL_1.0.2d
OPENSSL_1.0.2g
MD4 part of OpenSSL 1.0.2h 3 May 2016
MD5 part of OpenSSL 1.0.2h 3 May 2016
SHA part of OpenSSL 1.0.2h 3 May 2016
SHA1 part of OpenSSL 1.0.2h 3 May 2016
SHA-256 part of OpenSSL 1.0.2h 3 May 2016
SHA-512 part of OpenSSL 1.0.2h 3 May 2016
RIPE-MD160 part of OpenSSL 1.0.2h 3 May 2016
DES part of OpenSSL 1.0.2h 3 May 2016
libdes part of OpenSSL 1.0.2h 3 May 2016
AES part of OpenSSL 1.0.2h 3 May 2016
RC2 part of OpenSSL 1.0.2h 3 May 2016
IDEA part of OpenSSL 1.0.2h 3 May 2016
Blowfish part of OpenSSL 1.0.2h 3 May 2016
\CAST part of OpenSSL 1.0.2h 3 May 2016
CAMELLIA part of OpenSSL 1.0.2h 3 May 2016
Big Number part of OpenSSL 1.0.2h 3 May 2016
EC part of OpenSSL 1.0.2h 3 May 2016
RSA part of OpenSSL 1.0.2h 3 May 2016
DSA part of OpenSSL 1.0.2h 3 May 2016
ECDSA part of OpenSSL 1.0.2h 3 May 2016
Diffie-Hellman part of OpenSSL 1.0.2h 3 May 2016
ECDH part of OpenSSL 1.0.2h 3 May 2016
Stack part of OpenSSL 1.0.2h 3 May 2016
lhash part of OpenSSL 1.0.2h 3 May 2016
RAND part of OpenSSL 1.0.2h 3 May 2016
EVP part of OpenSSL 1.0.2h 3 May 2016
MIME-Version: 1.0%s
ASN.1 part of OpenSSL 1.0.2h 3 May 2016
PEM part of OpenSSL 1.0.2h 3 May 2016
X.509 part of OpenSSL 1.0.2h 3 May 2016
CONF part of OpenSSL 1.0.2h 3 May 2016
CONF_def part of OpenSSL 1.0.2h 3 May 2016
TXT_DB part of OpenSSL 1.0.2h 3 May 2016
%s %s HTTP/1.0
compiler: x86_64-nilrt-linux-gcc -m64 -march=core2 -mtune=core2 -msse3 -mfpmath=sse --sysroot=/mnt/build/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/5.0/objects/targettools/linuxU/x64/gcc-4.7-oe/release/build/tmp-glibc/sysroots/x64 -I. -I.. -I../include -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/mnt/build/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/5.0/objects/targettools/linuxU/x64/gcc-4.7-oe/release/build/tmp-glibc/work/core2-64-nilrt-linux/openssl/1.0.2h-r0=/usr/src/debug/openssl/1.0.2h-r0 -fdebug-prefix-map=/mnt/build/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/5.0/objects/targettools/linuxU/x64/gcc-4.7-oe/release/build/tmp-glibc/sysroots/x86_64-linux= -fdebug-prefix-map=/mnt/build/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/5.0/objects/targettools/linuxU/x64/gcc-4.7-oe/release/build/tmp-glibc/sysroots/x64= -Wall -Wa,--noexecstack -DHAVE_CRYPTODEV -DUSE_CRYPTODEV_DIGESTS -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DMD5_ASM -DAES_ASM -DVPAES_ASM -DBSAES_ASM -DWHIRLPOOL_ASM -DGHASH_ASM -DECP_NISTZ256_ASM
libcrypto.so.1.0.0
At this point I think the 2017 feed and library link in Eclipse is the root of the issue, but I don't see a solution to this. Any help would be appreciated. I am dead in the water on this topic.
Doug Ferguson
Message 5 of 11
(20,328 Views)
I've not seen this issue before, and have definitely used Eclipse with the 2017 feeds. That being said, part of the reason we created the Visual Studio Code tutorials was to avoid the often frustrating issues seen when configuring Eclipse for use with the cross compile toolchains. Most of the issues I've seen over the years with Eclipse were often just a missed configuration or a typo in one of the configs and I've made that mistake myself often enough to know that the errors that result are rarely helpful.
I could try to set up a simple "Hello, World!" for comparison in Eclipse, but it actually might just be faster if you tried the Visual Studio Code option instead, especially since that cuts out any "black magic" that Eclipse does in favor of open source tooling.
Charlie J.
Message 6 of 11
(20,284 Views)
To be clear, this project has been using Eclipse and the 2017 feeds successfully for years. The project is based on dcaf and even includes statically linked libraries. This issue arose because of the need to create a SHA256 hash and check it against a license key. I built the code and verified in Ubuntu (using Eclipse) before adapting the code to my C project in Eclipse (Windows). I was able to add the "crypto" library link and successfully build the application. However, it won't launch on the cRIO. I believe the issue is due to the shared object (libcrypto.so.1.0.0) in the 2017 toolchain not having the correct SONAME.
I am still developing in LabVIEW RT 2017, so I have few choices. I can strip the OpenSSL back and create my own hash code. Or I can upgrade to LabVIEW RT 2018-19 and migrate to Visual Studio Code.
I downloaded VSCode, created a helloworld project and successfully deployed to the cRIO. It is probably best to upgrade and move forward. But surly I am not the only person to use OpenSSL in 2017...
Doug Ferguson
Message 7 of 11
(20,279 Views)
I pulled the libcrypto.so.1.0.0 out of the C:\build\17.0\sysroots\core2-64-nilrt-linux\lib and checked the metadata:
dferguson@dferguson-HP-EliteDesk-705-G1-SFF:~/Documents$ strings libcrypto.so.1.0.0 | grep "1\.0"
libcrypto.so.1.0.0
OPENSSL_1.0.0
OPENSSL_1.0.1
OPENSSL_1.0.1d
OPENSSL_1.0.2
OpenSSL 1.0.2d 9 Jul 2015
MD4 part of OpenSSL 1.0.2d 9 Jul 2015
MD5 part of OpenSSL 1.0.2d 9 Jul 2015
SHA part of OpenSSL 1.0.2d 9 Jul 2015
SHA1 part of OpenSSL 1.0.2d 9 Jul 2015
SHA-256 part of OpenSSL 1.0.2d 9 Jul 2015
SHA-512 part of OpenSSL 1.0.2d 9 Jul 2015
RIPE-MD160 part of OpenSSL 1.0.2d 9 Jul 2015
DES part of OpenSSL 1.0.2d 9 Jul 2015
libdes part of OpenSSL 1.0.2d 9 Jul 2015
AES part of OpenSSL 1.0.2d 9 Jul 2015
RC2 part of OpenSSL 1.0.2d 9 Jul 2015
IDEA part of OpenSSL 1.0.2d 9 Jul 2015
Blowfish part of OpenSSL 1.0.2d 9 Jul 2015
\CAST part of OpenSSL 1.0.2d 9 Jul 2015
CAMELLIA part of OpenSSL 1.0.2d 9 Jul 2015
Big Number part of OpenSSL 1.0.2d 9 Jul 2015
EC part of OpenSSL 1.0.2d 9 Jul 2015
RSA part of OpenSSL 1.0.2d 9 Jul 2015
DSA part of OpenSSL 1.0.2d 9 Jul 2015
ECDSA part of OpenSSL 1.0.2d 9 Jul 2015
Diffie-Hellman part of OpenSSL 1.0.2d 9 Jul 2015
ECDH part of OpenSSL 1.0.2d 9 Jul 2015
Stack part of OpenSSL 1.0.2d 9 Jul 2015
lhash part of OpenSSL 1.0.2d 9 Jul 2015
RAND part of OpenSSL 1.0.2d 9 Jul 2015
EVP part of OpenSSL 1.0.2d 9 Jul 2015
MIME-Version: 1.0%s
ASN.1 part of OpenSSL 1.0.2d 9 Jul 2015
PEM part of OpenSSL 1.0.2d 9 Jul 2015
X.509 part of OpenSSL 1.0.2d 9 Jul 2015
CONF part of OpenSSL 1.0.2d 9 Jul 2015
CONF_def part of OpenSSL 1.0.2d 9 Jul 2015
TXT_DB part of OpenSSL 1.0.2d 9 Jul 2015
%s %s HTTP/1.0
libcrypto.so.1.0.0
 You can clearly see that the SONAME is listed as "OPENSSL 1.0.0" however the libcrypto in the 2107 software on the cRIO is "OPENSSL 1.0.2d".
Doug Ferguson
Message 8 of 11
(20,251 Views)
Hey Doug,
Can you check the versions of libssl in the sysroot used by eclipse compared against the ones on the cRIO? I'm not entirely sure what caused this, but it definitely looks like a mismatch between the toolchain and the cRIO install. Are you installing from the old RIO Software Set or from the feeds?
As a workaround, you might be able to just copy the relevant *.so files into the Eclipse sysroot. That should allow the cross compiler to link against the proper versions.
Charlie J.
Message 9 of 11
(20,149 Views)
Eclipse sysroot: "OPENSSL 1.0.0"
cRIO: "OPENSSL 1.0.2d"
Not sure what you mean by "Are you installing from the old RIO Software Set or from the feeds?"
I am installing through MAX. If I try to update OPENSSL through the feeds, it won't install because it says it is up-to-date. My guess is that either the Eclipse toolchain is old, or the feed is ahead.
I would think updating the Eclipse toolchain would be the best course, but this kind of scares me. The other idea would be to copy the OPENSSL folder to my project and statically load that library in the compile...
Doug Ferguson
Message 10 of 11
(19,955 Views)
