NI Linux Real-Time Discussions
Using an app that requires newer glibc version on ni Linux rt
I have an application that I need to run from my Linux rt system that complains about missing versions of GLIBC.
version `GLIBC_x.xxx' not found
Is there anyway to upgrade my GLIBC version on NI Linux RT to support this app. Or any other work around?
thanks
(2,166 Views)
I am facing the same issue. I am trying to run the ni_grpc_device_server version 2.7.0 on my PXI controller. The server application fails to launch since I missing version 3.4.29 of GLIBCXX.
Were you ever able to update your GLI library on your machine ?
Cheers,
Liam
(1,300 Views)
The glibc version is very tied into the version of the distro, in this case NI LinuxRT.
The simplest options, depending on the source of the software are:
  • Upgrade NI LinuxRT
  • Recompile the software on a system with an older glibc and/or use the cross compilation tool chain to build it
I realise these aren't always possible depending on your circumstances and the source of the software
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(1,288 Views)
