NI Linux Real-Time Discussions
Target Serial Number in Real Time
Is there any linux function that returns target (say, NI 9068) serial number and that I can use in real time? And also, is there any SSH command to see the serial number from command prompt in the host pc?
Thanks.
Rushd
(5,420 Views)
One way to do it in an SSH console is: fw_printenv serial#
or if logged in as lvuser: /sbin/fw_printenv serial#
(4,707 Views)
From LabVIEW, you can use the System Node to get the serial number (if it's running on a VI that's being run on the RT target, you will need to install the NI System Configuration package from MAX to that RT target)
(4,707 Views)
Thanks for the answers guys
Is there any C API to read the target's serial number?
(4,707 Views)
There is also a C API for NI System Configuration. This thread has some information on it, https://decibel.ni.com/content/thread/28062?tstart=0.
In general, I'd recommend using the System Configuration API over fw_printenv serial# since it abstracts any target differences and will continue to work with future targets. fw_printenv serial# may work going forward, but there is no gurantee.
(4,707 Views)
