NI Linux Real-Time Discussions
[SOLVED] myRIO-1950 - Wifi dongle driver compilation
Hi Aryk, thank you for your answer!!
I could compile the driver and replace it with new module.
But i want to know what's the best way to configure the device to connect network.
Do you have any incofmation which tells us the way?
Thank you!!
Message 21 of 40
(4,137 Views)
For that, you need to use wpa_supplicant:
Follow this procedure and that should work.
1. vi /etc/natinst/share/wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=ni
update_config=1
fast_reauth=0
network={
ssid="router ssid"
psk="passphrase"
priority=2
network={
ssid="ad-hoc wlan"
psk="passphrase"
priority=1
2. wpa_supplicant -B -iwlan0 -c /etc/natinst/share/wpa_supplicant.conf -Dwext && dhclient wlan0
3. ping google.com
This create a wpa_supplicant, and will connect in priority to an ad-hoc wlan, if not is found will then connect to a router if it is available. You have to lauch the 2. at startup every time for the dongle to work. The best is to create a boot-script for that, you have a tutorial available on the community documents.
Does that help?
Message 22 of 40
(4,137 Views)
thx!! I could make the device connect to network!!
Message 23 of 40
(4,137 Views)
I could use USB wifi dongle on myRIO-1900 but not on myRIO-1950...
According to lsmod, some module were not registered to blacklist.
admin@NI-myRIO-1950-030526be:~# lsmod
Module Size Used by
ipv6 271851 12
rtlwifi 71295 0
rtl8192c_common 54706 0
firmware_class 6337 0
mac80211 198512 2 rtl8192c_common,rtlwifi
cfg80211 181015 2 mac80211,rtlwifi
8192cu 598411 0
niriozynqk 190001 0
ehci_hcd 39556 0
NiRioSrvCompactRIO 585674 0
nibds 47467 2 NiRioSrvCompactRIO,niriozynqk
nikal 67570 3 nibds,NiRioSrvCompactRIO,niriozynqk
xilinx_xadcps 8395 0
hwmon 1191 1 xilinx_xadcps
There are "rtlwifi" and "rtl8192c_common" but they should be removed from module.
Ofcourse, I have edited /etc/modprobe.d/blacklist.conf and registered rtlwifi/rtl8192c_common/rtl8192cu.
But it seems that the configuration isn't recognized by myRIO-1950.
Anyone has same trouble and could solve this?
And I want to check your lsmod and myRIO process (by ps commend) log.
Thank you!
Message 24 of 40
(4,137 Views)
Hi all, we could make myRIO recognize USB wifi dongle by removing rtlwifi folder placed at
/lib/modules/3.2..../kernel/drivers/net/wireless/.
But i think it isn't correct(?) way.
Looking for some web page, we should type "update-initramfs -u" command on Ubuntu
to update blacklist configuration.
But myRIO doesn't have such command.
Does anyone know what command can be used on myRIO to do that.
And by typing wpa_supplicant command, it could connect to access point.
But i believe that it should connect automatically by DHCP.
Do you have any idea what does prevent the function?
Best,
Message 25 of 40
(4,137 Views)
You should be able to block rtlwifi from launching using by creating a blacklist.conf
vi /etc/modprobe.d/blacklist.conf
Add the entry: blacklist rltwifi
You seems to have already done it, but that's how I did it and it worked on the 1950.
You can also try to uninstall the module using
modprobe -r module.ko
and then install your freshly compiled module
modprobe module_fresh.ko
Sometimes giving a small ifconfig wlan0 up can also help you out
Is that helping?
Message 26 of 40
(4,137 Views)
Thank you for your info!!
I have created the file but it seems that the file doesn't work correctly.
"lsmod" command shows "rtlwifi" module....
And should type wpa_supplicant command to connect the device to AP.
Is the command needed or is there any way to connect automatically?
Message 27 of 40
(4,137 Views)
I've taken a closer look at your log and everything seems fine.
Every single time you boot need to type the wpa_supplicant command:
You can do a script that boots at startup to do that:
https://decibel.ni.com/content/docs/DOC-38960
Here an example of the script I've made to check if the connectivity is correct and synchronize the time to network using ntp&ntpdate protocols
#!/bin/bash
LOGNAME=network_init.log
LOGPATH=/home/admin/$LOGNAME
rm $LOGPATH
WLAN=ifconfig|grep wlan0
if [ -n $WLAN ]; then
    # Stop synchronization
    /etc/init.d/ntpd stop >> $LOGPATH
    echo "[-----------Initiating Network----------]" >> $LOGPATH
    #Set up Internet for the Wifi Dongle
    wpa_supplicant -B -iwlan0 -c /etc/natinst/share/wpa_supplicant.conf >> $LOGPATH
    dhclient wlan0 >> $LOGPATH
    echo "[-----------Connected to Network----------]" >> $LOGPATH
    ping -c3 google.com >> $LOGPATH
    # Launch Synchronization
    echo "[-----------Time Synchronization----------]" >> $LOGPATH
    ntpdate uk.pool.ntp.org >> $LOGPATH
    /etc/init.d/ntpd start >> $LOGPATH
else
echo "[-----------WIFI MODULE NOT PRESENT----------]" >> $LOGPATH
fi
Message 28 of 40
(4,137 Views)
Thank you so much for your information!!  I have a question related with this issue. But it's not difficult. When you could make compile and connect myRIO-1950 through wifi dongle,  could you see installed software on myRIO on MAX under remote systems tree?  We can connect the device and run some VIs but cannot see these detail on MAX... It means that we cannot upgrade the software through wifi and it will be trouble in the future.  Best,
Message 29 of 40
(4,137 Views)
NI Max will only care about NI product installed, serial ports, and USB to serial ports.
When you plug your USB cable, you don't see a USB connection under max, but you will see it using ifconfig
The wifi dongle drivers are added to the kernel, it is a part of linux and has nothing to do with NI or MAX.
When you got the connection right and the dongle working, you should be able to access the target through its IP address or its DNS name. It is exactly like having the USB cable plugged-in exept its through wifi. And you can of course, have the wifi dongle working & the USB cable at the same time.
MAX should be able to see that the device is online through wifi (USB cable unplugged), if it is not the case that means your target is not connected to the network or that your wifi dongle doesn't work properlly. If you can connect to the target and run VIs then you should be able to upgrade software, format and do all those stuff in MAX.
Message 30 of 40
(4,137 Views)
