NI Linux Real-Time Discussions
Recommended method for programmaticly getting files of of cRIO-9068
I believe I read somewhere that NI is officially not recommending FTP for a method of moving files off of the Linux-based targets ( although my google fu is failing me in finding that statement ).  There are a number of concerns with FTP's level of security, however, so I tend to agree with them if that is the statement they are making.
What is, if FTP is not it, the recommended way to programmatically get files from a cRIO-9068 to a windows host?  SCP sounds like the right answer, however that would require a bit of 'glue' on the windows side to get the files over from the target.  Additionally, serving up the files via the Web Services could be an option, but not one I particularly like, but would implement if needed.
Any insight is greatly appreciated.
-TD
(5,993 Views)
Hey,
This document in the help likely has the comment you're thinking of,
http://zone.ni.com/reference/en-XX/help/370622M-01/lvrtconcepts/rt_rtlinux/
The FTP server is disabled by default, and you cannot use it in safe mode. National Instruments recommends using WebDAV as the file transfer mechanism for improved security.
Once you have WebDAV installed on your target, there is an API you can use in LabVIEW for programmatic WebDAV. Its in the Data Communications > Protocols > WebDAV section.
We should have some other KB documentation on this as well to help guide you.
And last, there is an example project in the LabVIEW Example finder, "WebDAV Data Acquisition.lvproj" which shows how to acquire data from a Host RT Target and uses a WebDAV Sync.vi on the windows system to retrieve data from the target.
Tim A.
(4,724 Views)
Timothy,
Thank you for your quick reply.
With respect to security, could you comment on why NI picked WebDAV?  It appears that quite some time ago it was decided by the security folks that WebDAV is a security concern.  Granted that was primarily because it was the butt of many an exploit on IIS 6, but still it sounds like it's pretty insecure ...
ref links:
    http://www.networkworld.com/article/2202909/network-security/-webdav-is-bad---says-security-research...
    http://dl.packetstormsecurity.net/papers/general/webDAV-exploitation.pdf
Additionally, WebDAV is the primary way that Suxnet propagated so quickly:
    http://www.eset.com/us/resources/white-papers/Stuxnet_Under_the_Microscope.pdf
Any chance you could provide some additional information from NI that would put my mind at ease that there was a good justification for picking WebDAV over other technologies for file transfers?  How is WebDAV implemented on the cRIO-9068 device?  Is it using proven, industry code, or is it implemented from scratch from NI?  Is the code open source so it can be reviewed?
-TD
(4,724 Views)
We primarily chose WebDAV because it's an open standard accessible from
virtually all platforms. At minimum, every modern desktop can read files
from NI's RT targets using only a web browser (preferably via HTTPS).
There are also many readily available clients capable of both read and
write operations which users can download.
Security-wise, we chose it to leverage our existing web server
infrastructure that provides HTTPS and the necessary certificate
management tools for proper SSL configuration. A properly configured
HTTPS server (for WebDAV or any other web service) enables
authentication and encryption of in-flight data such that nobody can
eavesdrop communications or impersonate it.
> http://www.networkworld.com/article/2202909/network-security/-webdav-is-bad---sa ys-security-researcher.html
All of these appear to be problems with Windows WebDAV server and client,
not the WebDAV protocol or HTTP/S. To the best of my knowledge, NI's
implementations of WebDAV server (System Web Server) and client (LabVIEW)
are not vulnerable to these specific issues. However, someone could probably
exploit these issues in Windows using our tools. This is not something
we can address, aside from helping users configure RT security options
or disable WebDAV to curtail access. I can certainly help with that,
if you're interested.
WebDAV is provided by a plug-in module to System Web Server on all NI
RT targets (like cRIO-9068). We use an embedded server called AppWeb to
implement most of the server's logic. It's open source on github. But the
WebDAV plug-in is not.
(4,724 Views)
