NI Linux Real-Time Discussions
Open .db file on cRIO
Can I open a .db on cRIO? I need to create a database on cRIO to save some data. It will work as a datalogger.
(3,543 Views)
It really depends on what created the .db file (it's a very, very common extension). Also, I'm not really super clear on what it is that you want to do: you want to open a .db file on the cRIO, but you also want to create the .db file on the cRIO, is that right?
(3,530 Views)
Hi @gomezramones
I just found this post, probably it helps you.
(3,323 Views)
