NI Linux Real-Time Discussions
Multilingual Support on Embedded UI
Hello!
I'm using cRio 9031 to develop some heavy interface application.
The issue, I have right now, is that labels and text fields with russian symbols in dont display properly.
Is there a way to solve this problem w/o using web-based client, since there is already much work done?
I can replace labels with some graphics, but that doesn't  quite do it with text fields.
Thanks in advance.
(4,621 Views)
Hey e_rush,
You should direct this question to our technical support team since the problem is related to limitations of the LabVIEW Run-Time and Real-Time module and not the OS. They will be able to assist you further with your question.
Tim A.
(3,654 Views)
HI e_rush,
I think I know why it happens.
Please provide your contacts (skype or phone) and I'll share my experience. Too long to type
(3,654 Views)
Hi Arman,
I too have run into the same language support issues on embedded UI.  Currently I don't think NI is going to fix or patch this in the near future.  I need to show Chinese and Japanese text, so this is extremely problematic for me.  My only solution right now is to take a screenshot of the my UI, cut/copy pictures of the text lines and paste the "pictures" over them.  Same thing for labels on buttons, switches, etc.  This gets more tedious as I have more labels on the UI.  Can you point me in the right direction?  (Don't want to take up your valuable time, but just something to get me started.)
(3,654 Views)
