NI Linux Real-Time Discussions
Issues compiling C code using Cygwin and gcc 6.3 toolchain (oecore 6.0)
Hi, I am trying to use the latest toolchain for windows host (6.0 with gcc 6.3)
GNU C & C++ Compilers for x64 Linux (Windows host) 2018
with cygwin. I'm having problems compiling a simple code:
#include <stdio.h>
int main(void)
printf ("Hello from your first program!\n");
return 0;
if I use absolute unix-like path for sysroot. For example, after setting up the environment variables I issue a command like this:
x86_64-nilrt-linux-gcc -m64 -march=core2 -mtune=core2 -msse3 -mfpmath=sse --sysroot=/cygdrive/c/Users/Public/build/18.0/x64//sysroots/core2-64-nilrt-linux -O2 -pipe -o Test Test.c
I get this error:
Test.c:1:20: fatal error: stdlib.h: No such file or directory
#include <stdlib.h>
compilation terminated.
make: *** [MakeProgram:11: Test] Error 1
While if I use a relative path for sysroot and issue something like this:
x86_64-nilrt-linux-gcc -m64 -march=core2 -mtune=core2 -msse3 -mfpmath=sse --sysroot=../../../Public/build/18.0/x64/sysroots/core2-64-nilrt-linux -O2 -pipe -o Test Test.c
everything works fine.
Is it an expected behavior with cygdrive virtual directory? Is there anything I can do to avoid moving all absolute paths to relative ones?
Fabio M.
NI
Principal Engineer
Message 1 of 1
(2,830 Views)
