NI Linux Real-Time Discussions
Issue in mounting NFS share on compactRio-9068
I did tried auto option but it did not work either.
Somehow I feel that eth-0 and eth-1 interfaces are up after syetm trying to mount nfs during system power up inititalization. Is it a possiblity?  CompactRio power up console log is shown below. I could see n/w interface details are listed at the end. Not sure if that means those are up only at the end.
    Rebooting... [236433.339130] Restarting system.
    Booting LabVIEW RT...
    INIT: version 2.88 booting
    [    5.485962] generic-usb 0003:0835:8501.0001: claimed by neither input, hiddev nor hidraw
    [    6.803155] generic-usb 0003:0835:8502.0002: claimed by neither input, hiddev nor hidraw
    Applying large UDP packet fix to devices: eth0 eth1... done.
    vm.overcommit_ratio = 81
    INIT: Entering runlevel: 5
   Starting NI Service Locator: done
   Starting NiRioRpcServer: done
   BDS: Loading NiRioSrv (NiRioSrv) ... done.
   BDS: Loading bb_libk (bb_libk) ... done.
   BDS: Loading niriozynqk (niriozynqk) ... done.
  Starting systemWebServer: done
  Starting NIAuth: done
  Starting lkads: done
  Starting applicationWebServer: done
  done
  Starting NI-VISA Server...
  NI-VISA Server 5.4 started successfully.
  Interface eth0 - MAC addr: 00:80:2f:15:46:93 - 10.35.13.191/16 (primary - static)
  Interface eth1 - MAC addr: 00:80:2f:15:46:94 - 192.146.3.60/24 (static)
compactRio-9068 login:  NI Scan Engine initialized.
Welcome to LabVIEW Real-Time 13.0
Message 11 of 14
(3,482 Views)
Finally I got the solution. The issue was related to the absence of mountnfs service. CompactRio boots up with runlevel 5. After digging deeper, it was found that '/etc/init.d/mountnfs.sh' service is not not connected in /etc/rc5.d/ and was not getting executed.
I used following commands to connect it to rc5.d:
# cd /etc/init.d
# update-rc.d mountnfs.sh start 69 5 .
  Adding system startup for /etc/init.d/mountnfs.sh.
Note: Sequence number '69' is used here as at reboot level 6 (/etc/rc6.d/) the umountnfs.sh is running at sequence: 31. (standard rule: 100 - 31 = 69)
# ls -rtl /etc/rc5.d
  S69mountnfs.sh -> ../init.d/mountnfs.sh
After next power boot-up, I could see that my nfs share (defined in /etc/fstab) was mounted without any issue: (shown below)
# mount
rootfs on / type rootfs (rw)
ubi1:rootfs on / type ubifs (rw,relatime)
192.146.3.20:/tmp on /mnt/iasHome type nfs (rw,relatime,vers=3,rsize=524288,wsize=524288,namlen=255,hard,nolock,proto=tcp,port=2049,timeo=70,retrans=3,sec=sys,local_lock=all,addr=192.146.3.20)
Thank you BradM and TD for your help on guiding towards right direction.
--WillsG
Message 12 of 14
(3,482 Views)
This saved me a ton of time and worked great thanks so much for sharing!
Message 13 of 14
(3,482 Views)
Hi jdaming, good to know that it helped you. Thank you.
Message 14 of 14
(3,482 Views)
