NI Linux Real-Time Discussions
How to configure persistent static route on cRIO-9068
Reddata,
If you've not done system configuration through MAX or SysAPI calls, I can't think of any other mechanism that would cause customizations to the network interface to be lost. Basically, if you have a short list of operations that you did (outside of normal VI app development and deployment, unless those apps used SysAPI calls), that may help jog my memory or provide clues.
Message 11 of 13
(1,768 Views)
I spoke too quickly: In my changelog I found a deployment of NI TimeSync to all three chassis. If this is the issue, one of the three chassis surviving the update seems odd. Would deploying NI TimeSync revert ifplugd.script?
Message 12 of 13
(1,768 Views)
I have a sneaking suspicion that the CDF files (metadata for installable packages through MAX) for the two different target types (x64 vs. Zynq) is to blame for the differing behavior.
As such, I can absolutely believe that installing something that works with networking stuff (as TimeSync will) could impact interface customizations.
Message 13 of 13
(1,768 Views)
