NI Linux Real-Time Discussions
Guide: How to get Console Output in PuTTY Terminal without serial connexion
Ever since I startet using NI Linux RT I wanted to get a console output in the PuTTY terminal. Up untill now I have not found a way or guide for this. If this is a know way to get it, sorry.
So, in order to get the console output in the PuTTY terminal you need the following:
  ->Controller with NI Linux RT
      ->HTOP (opkg install htop) or whatever process manager you prefer
  ->Host PC
     ->PuTTY
     ->Admins rights
So:
1.Open the PuTTY Terminal and write # sudo htop
2. Press F5
3. Locate the following process
4. Press K and send a SIGNTERM
5. Locate the following process
6. Press K and send a SIGNTERM
7. Pres crt+c to terminate htop
8. terminal: # /bin/sh /etc/init.d/lvrt-daemon
The lvrt-daemon will start again from you terminal and you will have the console output there. Here is a screenshot!
I am using LV 2019. I do not really know which security implication come with this... if any
This can also be used to restart LV-RT in a target when it is not responsive anymore or to plug a monitor directly to the target, use # su to log as admin and use the same method to get the cosole output there. Of course you can also debug with front panels if you activate the embedded UI but yeah... I like my strings.
-A
Projektingenieur
Restbust, Simulations and HiL development
Custom Device Developer
(4,689 Views)
you could use
cat /dev/vcs
/dev/vcs is merely a mirror of the virtual console, which more or less always exists, even if you have neither serial nor VGA
Not sure what will happen with your approach with lvrt process once you disconnect your console.
~Jiri
CLA, CTA
(4,681 Views)
@ypi What information are you seeing with this process, that you cannot see by using PuTTY, connected to a serial port or through an SSH session?
David C
(4,633 Views)
Hey David,
VeriStand console log appears only on default console... So if you connect through putty you don't see the log on putty instance of the console.
~Jiri
CLA, CTA
(4,628 Views)
