NI Linux Real-Time Discussions
Ethernet Device Ping
I have an issue with the ping ethernet device from NI Real Time Linux running controller PXIe 8861. Following are the setup IP address and the Host PC, RT, and Ethernet Device is connected through unmanaged Switch.
RT Controller
Eth0 169.254.254.20 Mask 255.255.0.0
Eth1 Disabled
Ethernet Device
169.254.254.141 Mask 255.255.0.0
Host PC - Wins 10
169.254.254.110 Mask 255.255.0.0
From Host Machine – able to ping Ethernet Device & RT both Eth0.
From RT Machine – able to Host IP but not Ethernet Device.
I have checked the iptable which accepts all connections.
Please provide some inputs, am I missing something.
(1,811 Views)
What happens if you change from link-local addresses (169.254.x.x) to private addresses (192.168.x.x)?
Certified LabVIEW Developer
(1,769 Views)
