NI Linux Real-Time Discussions
Create System Image of PXI running NI Linux RT?
Using LV 2021, I tried to create an image of a PXI system running NI Linux RT using the system config library VIs.
However I got an error -2147220364 "NI system configuration is not supported by given protocol".
Does the Create System Image VI not work with NI Linux RT or something?
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
(2,175 Views)
It looks like this a known issue. There is a KB that discusses it:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000wwarCAA&l=en-US
You can also test with the Replication and Deployment tool, as it uses the System Configuration API:
https://www.ni.com/en-us/support/downloads/software-products/download.replication-and-deployment-uti...
The source code is on GitHub:
https://github.com/ni/rad
(2,163 Views)
Unfortunately I'm just a moron that didn't wire a target IP to the open session VI...
(2,159 Views)
