NI Linux Real-Time Discussions
Copy disk using the command "dd"
I have a new question following the last one I asked. https://forums.ni.com/t5/NI-Linux-Real-Time-Discussions/Start-PostgreSQL-on-startup/td-p/4052542?pro...
Because the installation take time and it is possible to make an error, I wanted to find a solution to copy an image from an sbRIO with PostgreSQL already installed to a new one.
I tried using the command "dd", but we the sbRIO is using virtual memory instead of disk like Linux computer if I can say. With that in mind, I have multiple mtdblock (0 to 😎 and each one containing information.
First, I can use the command for the blocks 0 to 5, but the terminal tell me that the bock 6-8 are busy when I try to copy them.
Secondly, when I copy the images (0-5) previously saved on a USB stick to the RT target and I reboot the system, the system fail and I have to restart it in safemode.
Maybe it isn't the "right" way to do what I want to do.
I was wondering what I was doing wrong and if there was a guide or a tutorial somewhere that I can follow.
Thank you
Message 1 of 1
(2,123 Views)
