NI Linux Real-Time Discussions
Bitbake error
Hi, I'm trying to install the library "LAPACK 3.0" on a linux64 device. For this library to be installed, the compiler "gfortran" is needed. As building the compiler directly in the linux device concludes in an error,  I tried to make the cross-compiling from an external linux.
I'm trying to make the cross-compiling of the library libgfortran on a virtual machine in a windows pc, to later build the library on a linux device. I'm following the guide from this page.
Following the guide I have encountered two problems:
  • When I execute the command "git cherry-pick de2aa7a56790581406f219339c9022638cd47494", I get the error "fatal: bad object".
  • After that, when I arrive to the "bitbake libgfortran" command, the following error appears:
ERROR: Function failed: do_compile (log file is located at /home/burruzola/nilrt/build/tmp_nilrt_3_0_x64-glibc/work/x86_64-linux/automake-native/1.14.1-r0/temp/log.do_compile.4677)
ERROR: Logfile of failure stored in: /home/burruzola/nilrt/build/tmp_nilrt_3_0_x64-glibc/work/x86_64-linux/automake-native/1.14.1-r0/temp/log.do_compile.4677
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 6
| : && /bin/mkdir -p doc && { PATH='/home/burruzola/nilrt/build/tmp_nilrt_3_0_x64-glibc/work/x86_64-linux/automake-native/1.14.1-r0/build/t/wrap':$PATH && export PATH; } && /usr/bin/perl /home/burruzola/nilrt/build/tmp_nilrt_3_0_x64-glibc/work/x86_64-linux/automake-native/1.14.1-r0/automake-1.14.1/doc/help2man --output=doc/automake-1.14.1 automake-1.14
| help2man: can't get `--help' info from automake-1.14
| Try `--no-discard-stderr' if option outputs to stderr
| Makefile:3707: recipe for target 'doc/automake-1.14.1' failed
| make: *** [doc/automake-1.14.1] Error 255
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
Although a "build" folder is created with a subfolder for the machine inside it, the .ipk files are nowhere to be found as the bitbake command is not fully completed.
How can I solve it?
Message 1 of 1
(2,677 Views)
