‎12-31-2012 10:08 AM
I dont know, haven't tried it yet
‎01-02-2013 02:46 PM
Thanks for stroking my ego Steve!
I heavily doubt that it would be possible to get this to work in simulation mode without R&D ownership and probably a good amount more work.
Are you planning on posting any of your DMA Logging Daemon? If you come back for NI Week, maybe we could get you to give a presentation...
Happy New Year!
-Mike
‎01-02-2013 07:41 PM
Happy New Year to you too
Hey man, this is really great product completion material and makes certain operations so much more natural - dare I say correct. When you do great work, you deserve a good st... Thanks for confirming the simulation aspect. It's so silly to think about using the FPGA Interface API to wrap the advanced dynamic interface API for simulation mode
I'm still learning about the processes here, and it's clear that publication requires some. I don't know if this will make it online (given my deadlines, I don't know if this will materialize at all), but I appreciate your encouragement.
Miss you buddy !
‎01-16-2013 06:02 PM
Hello Mike,
This tool is very good, it makes the devloper life easier for reuse. I have a question. I have cluster of five I32 numbers as control in FPGA VI. Create FPGA Interface tool does not list these elements of cluster. Does this tool support cluster of elements in FPGA code?
A Senthilnathan
‎02-18-2013 08:29 PM
Any plan to support SGL data type in FPGA Read/Write by Name function?
‎02-19-2013 09:26 AM
Good idea. I'll look into adding that when I upgrade to 2012 soon.
‎02-22-2013 11:32 AM
2012 support has been added
‎02-24-2013 08:37 PM
I got the following paletter after install on LabVIEW 2012. Is it correct? Why one VI is missing?
By the way, it looks like I have to run LabVIEW as Administrator to install the addon. Otherwise, LabVIEW is not able to copy file to National Instruments\Shared\Errors folder. The OS is Windows 7.
‎02-25-2013 03:44 PM
Yes you likely need admin privledges.
Hmm.. the palette seems a little weird. I just confirmed that behavior on my side. The top left and bottom left items shouldn't be there. I'll see if I can fix this. Until then, they can be safely ignored
‎04-17-2013 01:19 PM
having difficult with the installer vi, getting error messge saying the file is not available. I put the file in different locations and getting same error message.
Abdul
