NI Labs Discussions
Interface with Codesys Application using LabVIEW
I have a query with respect to interfacing codesys application using LabVIEW.
I would like to interface with codesys appplication (access to variables in Codesys/models) using LabVIEW. The idea is to test the Codesys application using LabVIEW.
I tried using ActiveX communication, but I am unable to communicate with the codesys application.
Any ideas on this would be really helpful.
Naresh
(7,574 Views)
Hello Naresh:
What is your target runtime system of Labview?
What is your target runtime system of Codeys?
There are many possible ways to realize this communication:
1, with CODESYS PLC Handler  -> need the license from 3s
2. OPC          -> need OPC Server license
3.Standard field-bus: MODBUS TCP/Profinet....   -> may need additional hardware or software license.
4. TCP/IP:  you need encode and decode the data,this need to developed in low lever
(5,916 Views)
